Novo Sanwa/Aitronics M12
15 mensagens
Acabei de ler essa notícia, via neo-buggy.net:
Sanwa announce M12 radio
Apesar de não ter muitas informações, parece que vai ter telemetria também.
Pessoalmente, eu achei muito bonito, tem um design parecido ao do MT-4:
![Imagem](http://www.neobuggy.net/images/News/m122.jpg)
![Imagem](http://www.neobuggy.net/images/News/m12.jpg)
Re: Novo Sanwa/Aitronics M12
gconstroi escreveu:Lindo rádio. Será o substituto do M11x?
Tudo leva a crer que sim, este seria o novo topo de linha da Airtronics, substituindo o M11x.
Consegui mais especificações sobre o M12 (obtidas do site Competition X):
New Features:
● Select car type racing mode
● LOG set up safety features
● Telemetry link
● Boot menu feature (REC / RPM / VOLT/ TEMP1 / TEMP2 / RX MODE / ST POINT / TH POINT)
● Monitoring
● PC-LINK
● Language
● Information
● Ackerman (dual steering)
● Racing mode delay curve
● CODE AUX1/AUX2
● Feeling custom menu
● Monitor menu selector large full-dot LCD (9/18 points)
● 128 × 256 (body double built-in antenna)
● Fully adjustable trigger multi-selector operation
UP feature from the M11X:
● Throttle battery fail-safe type model for direct select
● Li-PO (70:30 / 50:50)
● Point AUX1/AUX2 (2 ~ 6 points)
● 4WS mixing (FRONT / REAR / NORMAL) / REVERSE phase ( )
● MOA mixing (reverse phase)
● Variable speed drive ratio (rear-wheel drive / four-wheel drive / front-wheel drive ((ST / TH)
● Offset channel set sorting model
Other features
● ST, memory function
● Switching function model left and right driving position TH tension adjuster
● 50 model memory
● Model model name (14 characters) set (select / copy / clear)
● RF MODE (FH4T/FH4FT/FH3/FH3F)
● monitor the response mode setting
● Servo bind key note assignment (NOR / SHR / SSR) ※ (SW / TRIM / DIAL / LEVER)
● Vibrating reminder
● LCD contrast setting buzzer
● AUX TYPE (scale and volume change) (AUX/AUX1 / AUX2)
● Trim type (center / parallel)
● User name battery alarm
● End point adjustment trim / reverse servo sub trim
● Fail-safe characters (14 radio)
● Timer (lap / interval a / interval 2)
● Dual rate curve (exponential / adjustable rate control / point curve)
● Brake anti-lock brake mixing throttle hold
● Compensation mixing (C-MIX1/C- RX-471, RX-451R, RX-451, RX-381, RX-461, RX-462: support)
● 4 cell receiver rudder adjustment formula MIX2)
Accessories:
● Grip pad (Large / Small)
● Large steering wheel steering bracket
● Steering slant offset bracket
OBS: estas são informações em inglês, traduzidas direto do japonês [http://www.sanwa-denshi.co.jp/rc/car/propo/m12.html], por isso que esta nomenclatura tá meio estranha pra algumas funções...
New Features:
● Telemetry link
● Monitoring
● PC-LINK
● Language
● Information
● CODE AUX1/AUX2
Other features
● 50 model memory
Accessories:
- carholanda1977
- Registrado em: 13 Nov 2011, 21:00
Já tem noção de preço ? Putz estava fechando um MX11 AGORA vou esperar um pouco !
Abraços,
Carlos
Abraços,
Carlos
Teoria de um louco porque nem todos tiveram motivos para serem normais !
Mugen Mbx6r
Mugen Mbx6r
carholanda1977 escreveu:Já tem noção de preço ? Putz estava fechando um MX11 AGORA vou esperar um pouco !
Abraços,
Carlos
Sem notícias sobre o preço.
Mas eu chuto que vá custar em torno de 400 doletas...
cardinal escreveu:carholanda1977 escreveu:Já tem noção de preço ? Putz estava fechando um MX11 AGORA vou esperar um pouco !
Abraços,
Carlos
Será que vai custar U$ 400...cardinal?rsssss
Eu chuto uns ....U$ 500,00 pra mais....deve ser no mesmo valor do novo radio da Ko...será que não?
Editado pela última vez por Kimo em 03 Mai 2012, 15:04, em um total de 1 vez.
Kimo escreveu:Será que vai custar U$ 440...cardinal?rsssss
Tomando por base o preço do M11X, eu acho que ele venha com um MSRP (manufacturer's suggested retail price) de USD 499, o que resultaria em um preço real cerca de USD 429 para o mercado americano e uns USD 399 na Ásia.
Acho que não vai ser tão caro quanto o KO EX-1 K.I.Y. porque o KO é um conceito "modular" completamente novo, que envolveu mais custos de P&D, enquanto o M12 é um misto das funções do M11x com o design e a telemetria do MT-4, num "corpo" mais convencional.
Vamos fazer um bolão sobre o preço?
KKKKK
Deus te ouça Gconstroi.......kkkkkkk
Se bem que com esses lançamentos de radio...quem tem m11x, ex-10..dx3rpro,4pks....estão bem servidos ...pois eles são excelentes rádios, independente dos lançamentos( minha opnião).
Opaaaa!!!
Primeira "pré-venda" do M12 que eu encontro:
http://rcmarket.com.hk/product_info.php ... a62bb627ab
Poucas informações disponíveis, mas as mais relevantes seriam a versão (Japan), o preço (USD 500) e a data de chegada (dia 7 de julho).
Tá chegando!
Tá chegando!
Mais um pouco de informação!
As primeiras unidades do M12 japonês já chegaram às mãos de alguns gringos.
Esse cara fez algumas fotos do M12 ao lado do antigo M11x dele:
http://imageshack.us/photo/my-images/850/imagetkm.jpg/
E aqui tem um vídeo (meio tremido) mostrando detalhes interessantes:
http://www.youtube.com/watch?v=o8JNBpkOB4Q
Opa!!
O M12 apareceu na última sexta-feira (21) pra venda na RC-Mushroom, mas já esgotou:
Sanwa/Airtronics M12 Radio with RX-471 Receiver
Mas ainda tem em estoque na RC Mart por USD499.00:
Sanwa 2.4Ghz FHSS-4 4Channels Transmitter set with receiver #M12
E também da A-Main por USD599.00:
Airtronics M12 FHSS-4 2.4GHz Radio System w/92014 4-Channel Receiver
Na TowerHobbies por USD450.00 com cupom de desconto:
http://www3.towerhobbies.com/cgi-bin/wt ... XCVAL&P=ML
15 mensagens
