Carregador LIPO LIFE
2 mensagens
- rodrigolopes
- Registrado em: 23 Ago 2008, 23:00
olá boa tarde
Compro carregador de lipo e life!
Retiro no local -sp e abC
Nenhuma proposta em andamento.
futaba 2PL 2.4 fhss |
- firehs
- Registrado em: 29 Jan 2007, 21:00
Re: Carregador LIPO LIFE
Boa noite,
Tenho para venda um Bantam E-station BC6 com dual fonte.
Segue as especificações:
This is the Bantam Hobby Technology E-Station BC6. The E-Station BC6 is a microprocessor controlled high performance rapid charger and discharger for NiCD, NiMH, Lithium Polymer and Pb batteries. The E-Station BC6 features dual input power (AC/DC) and an easy to operate programming. All of the basic factors are optimized and pre-programmed for easy operation and maximum safety. The BC6 employs a high-quality aluminum outer case that is durable and efficient to cooling internal heat.
Optimized operating software
When charging or discharging, BC6 has an 'AUTO' function that sets the feeding current or the cell count of Lithium battery automatically. Especially for Lithium batteries, it can prevent the over-charging can lead to an explosion by users fault. Every program in the unit is controlled with mutual links and communication for every possible error so it introduces a maximum safety. These can be set at users option.
Dual input power
The E-Station BC6 employs the circuit that can be operated with the input power of AC(Alternating Current) or DC(Direct Current). For AC input, it contains a AC-DC switching power supplier which has 5A of power capacity and maximum output power of 50Watts for charging. As a result it can charge up to 15 cells of NiCd/NiMH and 6 series of Lithium batteries with maximum current of 5.0A.
Individual voltage balancer for Lithium batteries inside
The E-Station BC6 has an individual-cell-voltage balancer inside. So it does not need any balancer separately when charging Lithium batteries (LiIo/LiPo/LiFe) for cell voltage balancing.
Balance individual cells on discharge
The E-Station BC6 also can monitor and balance individual cells of the Lithium battery pack during the discharge process. If the voltage of any one cell varies abnormally, the process will be stopped with the error message.
Accept various types of Lithium battery
The E-Station BC6 can accept three types of Lithium batteries - LiIo, LiPo and LiFe. They have different characteristics by their chemistry. You can select any one of them that you are going to process before the job.
Lithium battery 'Fast' and 'Storage' mode
You can charge Lithium battery for special purposes. 'Fast' charge reduces the charging time of Lithium battery and 'Storage mode controls the final voltage of the battery to be suit for long time storage.
Data store/load
For users convenience it can store maximum 5 data of different batteries. You can establish the data contains program setting of the battery to charge or discharge continually. These data can be called out at any time you need and the process can be executed without program setting.
Cyclic charging/discharging
Perform 1 to 5 cycles of charge>discharge or discharge>charge continually for battery refreshing and balancing.
PC based analysis using USB communication
For technical expert, the E-Station BC6 offers PC based program can analysis the characteristic of the battery by USB port. It shows a graph of voltage, current, capacity and temperature curves. It also shows the individual voltage of each cell in the Lithium battery pack.
Robust outer aluminum case
High-quality aluminum case is durable and very efficient to cool out the internal heat
Specifications:
Operating voltage: DC 11~18 volts; AC 100~240V
Charge/Dischage Power: max. 50/5W
NiCD/NiMH: 1~15 cells
Li-polymer: 1~6 series
Pb: 2~20V
Charge current: 0.1 to 5A
Discharge current: 0.1 to 1.0A
No. of cycles: 1 to 5 times
Battery Data memory: up to 5 data
Weight: 960g
Dimension: 160x120x40mm
Att,
Gustavo
Dual input power
Data store/load
Specifications:
Pb: 2~20V
Weight: 960g
Att,
Gustavo
Mugen MBX-6 Ninja JX21 B01A Airtronics M11X |
2 mensagens
