carregador Bantam bc6
1 mensagem
- maxrcp
- Registrado em: 18 Mai 2006, 23:00
Vendo um Bantam E-station BC6 com dual fonte (12v e AC/DC, serve na bateria ou na tomada sem precisar de fonte). R$ 350,00
carregador muito novo, usado umas 5x apensa em casa, mando fotos em alta resolucao no whats. (44) 98203256
sem marcas de uso, sem ralados nen nada, ainda tem o plastico original em cima do visor!
Carregador na caixa, com manual, com todos os acessórios originais, mais o cabo opcional balance adapter e o multi plug.
Fotos reais do produto.
Segue as especificações:
This is the Bantam Hobby Technology E-Station BC6. The E-Station BC6 is a microprocessor controlled
high performance rapid charger and discharger for NiCD, NiMH, Lithium Polymer and Pb batteries. The
E-Station BC6 features dual input power (AC/DC) and an easy to operate programming. All of the basic
factors are optimized and pre-programmed for easy operation and maximum safety. The BC6 employs a
high-quality aluminum outer case that is durable and efficient to cooling internal heat.
Optimized operating software
When charging or discharging, BC6 has an 'AUTO' function that sets the feeding current or the cell
count of Lithium battery automatically. Especially for Lithium batteries, it can prevent the over-
charging can lead to an explosion by users fault. Every program in the unit is controlled with
mutual links and communication for every possible error so it introduces a maximum safety. These can
be set at users option.
Dual input power
The E-Station BC6 employs the circuit that can be operated with the input power of AC(Alternating
Current) or DC(Direct Current). For AC input, it contains a AC-DC switching power supplier which has
5A of power capacity and maximum output power of 50Watts for charging. As a result it can charge up
to 15 cells of NiCd/NiMH and 6 series of Lithium batteries with maximum current of 5.0A.
Individual voltage balancer for Lithium batteries inside
The E-Station BC6 has an individual-cell-voltage balancer inside. So it does not need any balancer
separately when charging Lithium batteries (LiIo/LiPo/LiFe) for cell voltage balancing.
Balance individual cells on discharge
The E-Station BC6 also can monitor and balance individual cells of the Lithium battery pack during
the discharge process. If the voltage of any one cell varies abnormally, the process will be stopped
with the error message.
Accept various types of Lithium battery
The E-Station BC6 can accept three types of Lithium batteries - LiIo, LiPo and LiFe. They have
different characteristics by their chemistry. You can select any one of them that you are going to
process before the job.
Lithium battery 'Fast' and 'Storage' mode
You can charge Lithium battery for special purposes. 'Fast' charge reduces the charging time of
Lithium battery and 'Storage mode controls the final voltage of the battery to be suit for long time
storage.
Data store/load
For users convenience it can store maximum 5 data of different batteries. You can establish the data
contains program setting of the battery to charge or discharge continually. These data can be called
out at any time you need and the process can be executed without program setting.
Cyclic charging/discharging
Perform 1 to 5 cycles of charge>discharge or discharge>charge continually for battery refreshing and
balancing.
PC based analysis using USB communication
For technical expert, the E-Station BC6 offers PC based program can analysis the characteristic of
the battery by USB port. It shows a graph of voltage, current, capacity and temperature curves. It
also shows the individual voltage of each cell in the Lithium battery pack.
Robust outer aluminum case
High-quality aluminum case is durable and very efficient to cool out the internal heat
Specifications:
Operating voltage: DC 11~18 volts; AC 100~240V
Charge/Dischage Power: max. 50/5W
NiCD/NiMH: 1~15 cells
Li-polymer: 1~6 series
Pb: 2~20V
Charge current: 0.1 to 5A
Discharge current: 0.1 to 1.0A
No. of cycles: 1 to 5 times
Battery Data memory: up to 5 data
Weight: 960g
Dimension: 160x120x40mm
Dual input power
storage.
Data store/load
balancing.
Specifications:
Pb: 2~20V
Weight: 960g
Nenhuma proposta em andamento.
Maringá |
1 mensagem
Usuários navegando neste fórum: Nenhum usuário registrado e 9 visitantes
