Vendo Servo Futaba 3305 e Hitec Digital HS5625MG
8 mensagens
- lmaimone
- Registrado em: 30 Ago 2006, 23:00
Vendo Servos
Futaba S3305 - Hi Torque
R$100,00
Hitec Digital - HS5625MG
R$100
Usados mas em PERFEITO estado, tanto de aparecia, qnto de funcionamento.
R$100,00
R$100
A Proposta (nº 152563) do usuário Hamilton_brz (34 pts) foi aceita! O usuário lmaimone deu uma qualificação POSITIVA para o usuário Hamilton_brz. O usuário Hamilton_brz deu uma qualificação POSITIVA para o usuário lmaimone.
- lmaimone
Re: Vendo Servo Futaba 3305 e Hitec Digital HS5625MG
Fotos
- ricamaimone
- Registrado em: 01 Jun 2006, 23:00
Ajuda nas especificações. o Futaba 3305 todos jah conhecem , segue as especificações do Hitec
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXUZ76
FEATURES: EPA, Speed, Direction, and Fail-Safe Programmable (see COMMENTS).
MOSFET amplifier.
Gold plated contacts.
Three metal gears
Dual ball bearings.
Indirect drive long life potentiometer.
High standing torque.
Watertight and dustproof.
Includes blue aluminum, heat-treated servo arm (see COMMENTS).
Works with fixed winged aircraft and helicopters up to 40 pounds,
1/10th and 1/8th on- or off-road vehicles.
INCLUDES: One digital high torque servo with 12" wire and S/JR/Air-Z connector
One white small X-shaped servo horn.
One red Large X-shaped servo horn.
One white adjustable servo horn.
One white off-set straight servo horn.
One white disc servo horn.
One blue aluminum, heat-treated servo arm horn.
Four 2 x 14mm mounting screws
Four brass eyelets
Four black rubber vibration isolators.
REQUIRES: Hitec, JR and Airtronics-Z radio system
SPECS: Speed: 0.17 sec/60° at 4.8V
Speed: 0.14 sec/60° at 6.0V
Torque: 109.7 oz-in at 4.8V
Torque: 130.53 oz-in at 6.0V
Length: 1.59" (40.6mm)
Width: 0.77" (19.8mm)
Height: 1.48" (37.8mm)
Weight: 2.11oz (60g)
MOSFET amplifier.
Three metal gears
Dual ball bearings.
Four brass eyelets
MAIMONE RACING TEAM
http://www.maimone.com.br/rc
G4+ Novarossi Futaba 3PKS O`Donell DNA GQ 14 Bis / APPA / AARC ... |
- caio_bonaldi
- Registrado em: 17 Ago 2008, 23:00
Aceita por algum item do link abaixo?
/viewtopic.php?t=16456
Bateria e Amplificador reservados.
Obrigado,
Obrigado,
- lmaimone
caio_bonaldi escreveu:Aceita por algum item do link abaixo?
Obrigado,
Troca somente por DIN DIN R$
heheh
- lmaimone
ReyBarroco escreveu:mp
MP respondida...
Ambos ainda a venda
- Hamilton_brz
- Registrado em: 28 Mar 2006, 23:00
Combinei com o Ricardo por MP
Negociação:
[ ]s
Hamilton Sérgio
Hamilton Sérgio
Serpent 988/Mugen NTC1/IGT8 NOVAROSSI/KABUTO/XRD KO EX2 RR Byron 25% Blitz Enetti/matrix Parque Jundiai/APPA |
8 mensagens
