[VENDO] Servos NOVOS na caixa Team Orion HV 16KG 0,05s metal gears
3 mensagens
- gmassini
- Registrado em: 06 Abr 2006, 23:00
Vendo servos TEAM ORION VORTEX DIGITAL SPEED VDS2-HV 1605 ORI68026
tenho 02 peças.. valor é unitário 300,00R$
16kg
0,05s
High Voltage
descrição
Specifications
Operating voltage: 4.8 to 7.4 V, regulating speed: 0.05 s/60 °; Torque: 16 kg / cm, dimensions: 41 x 20 x 40 mm Weight: 62 g
Description
Impress with precision and power, the new Vortex VDS2 digital high performance servos from Team Orion. From the experiences of proven Vortex servos and innumerable successes in competitions could after several years of development with the help of Team Orion Team pilots are completely created from scratch new product line. In addition to an outstanding performance, was primarily on the shelf at the forefront in the development. This work has a compact high-power line that fits on the market for all-electric and nitro car classes.
The servos are presented in a case made of plastic and aluminum, which ensures optimum heat dissipation and resistance to breakage.
When heavy-duty gearbox complex exclusively come CNC machined for use. This results in outstanding strength resulting in an extremely low weight and minimal wear. The mounting of the servos by two high precision ball bearings.
With their particularly high holding torque, the vortex servos are particularly suitable for use in the field of competition. While servos can rotate away from other manufacturers from the selected position with some force, show the Vortex Digital Servos maximum stability. Using exceptionally powerful coreless electric motors and specially developed electronics with ultra-fast response time, include the Vortex Digital Servos are the leaders.
Another thoughtful feature are the power numbers. They are coded so that the first two digits of the actuating force and the last two digits represent the operating time. Whether parking racer or professional competition - the Vortex Digital Servos impress with performance and durability.
Features
• Digital high-voltage power
• Precise coreless motor drive
• Heavy-duty all-metal transmission
• Facilitated drive gears
• 25T driven gear for Futaba servo horns
• Double ball bearings
• special pot with anti-fading coating
• Dust and splash-proof aluminum-plastic housing
• High recovery accuracy
• High holding torque
• JR / hitec connector system
• Different servo horns included
Target Audience
• 1:10 / 1:8 Offroad (gas / brake, steering)
• 1:10 / 1:8 Onroad (gas / brake, steering) Preço de venda: 300
16kg
0,05s
High Voltage
descrição
Specifications
Description
Features
Target Audience
A Proposta (nº 528174) do usuário rcp_potenci (91 pts) foi aceita! O usuário gmassini deu uma qualificação POSITIVA para o usuário rcp_potenci. O usuário rcp_potenci deu uma qualificação POSITIVA para o usuário gmassini.
- gmassini
Re: [VENDO] Servos NOVOS na caixa Team Orion HV 16KG 0,05s metal gears
vendido
EDAM Spirit Gold NovaRossi Flash.12 3PK Spektrum MKFuel Stratus 3.1 GRP ACARC |
- rcp_potenci
- Registrado em: 28 Mar 2006, 23:00
Opa
Enviado MP...
Enviado MP...
Negociação:
3 mensagens
