[VENDO] Peças Associated rc8/rc8.2/rc8T
12 mensagens
- sotelo
- Registrado em: 25 Fev 2007, 22:00
Peças Associated
A lista é grande. Praticamente o preço que eu paguei.
ASC89007 TEAM ASSOCIATED STEERING SERVO HORNS R$ 15.1
ASC89017 TEAM ASSOCIATED FRONT OR REAR GEAR BOX R$ 20
ASC89030 TEAM ASSOCIATED CASTER BLOCKS (RC8) (2) R$ 20
ASC89031 TEAM ASSOCIATED CASTER/HUB SPACERS (RC8) (Cool R$ 10.1
ASC89032 TEAM ASSOCIATED CASTER ANGLE BUSHINGS (RC8) (12) R$ 12.6
ASC89033 TEAM ASSOCIATED HUB CARRIER (RC8) (2) R$ 15.1
ASC89039 TEAM ASSOCIATED HINGE PIN BUSHINGS (RC8) R$ 12.6
ASC89064 TEAM ASSOCIATED SHOCK REBUILD KIT (RC8) R$ 25.4
ASC89074 TEAM ASSOCIATED STEERING ROD ENDS (RC8) R$ 7.7
ASC89076 TEAM ASSOCIATED CAMBER ROD ENDS (RC8) R$ 15.1
ASC89078 TEAM ASSOCIATED SERVO LINK ROD ENDS (RC8) R$ 10.1
ASC89083 TEAM ASSOCIATED SHOCK BUSHINGS (RC8) (4) R$ 7.7
ASC89094 TEAM ASSOCIATED FACTORY TEAM NYLOC HEX WHEEL NUTS (RC8) (2) R$ 15.1
ASC89095 TEAM ASSOCIATED ALUMINUM WHEEL HEX (RC8) R$ 17.6
ASC89096 TEAM ASSOCIATED WHEEL HEX PINS (RC8) (4) R$ 5.2
ASC89102 TEAM ASSOCIATED FRONT/REAR CVA BONE R$ 61.8
ASC89105 TEAM ASSOCIATED CVA REBUILD, FRONT OR REAR (RC8) R$ 10.1
ASC89106 TEAM ASSOCIATED CENTER CVA REBUILD SET (RC8) R$ 12.6
ASC89107 TEAM ASSOCIATED REAR CVA SHIELD & BOOT (RC8) R$ 12.6
ASC89116 TEAM ASSOCIATED DIFFERENTIAL GASKET (RC8) R$ 7.7
ASC89117 TEAM ASSOCIATED DIFFERENTIAL SHIMS (RC8) R$ 7.7
ASC89120 TEAM ASSOCIATED DIFFERENTIAL GEARS, WASHERS, AND PINS (RC8) R$ 30.2
ASC89121 TEAM ASSOCIATED DIFFERENTIAL O-RINGS (RC8) (12) R$ 7.7
ASC89131 TEAM ASSOCIATED FUEL TANK (RC8) R$ 61.8
ASC89133 TEAM ASSOCIATED CLUTCH SPRINGS 1.0 (RC8) (3) R$ 10.1
ASC89134 TEAM ASSOCIATED CLUTCH SHOES WITH SHIM (RC8) R$ 72.8
ASC89226 TEAM ASSOCIATED 3X26MM SHC SCREWS (10) R$ 12.6
ASC89265 TEAM ASSOCIATED FIBER CLUTCH SHOES (RC8RS) R$ 35.1
ASC89284 TEAM ASSOCIATED FACTORY TEAM ALUMINUM REAR STUB AXLE (2) (RC8) R$ 72.8
ASC89285 TEAM ASSOCIATED FACTORY TEAM ALUMINUM FRONT STUB AXLE (2) (RC8) R$ 72.8
ASC89286 TEAM ASSOCIATED FACTORY TEAM ALUMINUM GEARBOX INPUT CUP (2) (RC8) R$ 49.5
ASC89316 ASSOCIATED RC8T SHOCK RISERS W/PINS R$ 17.5
ASC89319 ASSOCIATED RC8T AIR FILTER BOOT R$ 7.7
ASC89324 RC8T FUEL TANK R$ 65
ASC89341 TEAM ASSOCIATED 16X32MM FRONT SPRING (BRONZE) (2) R$ 15.1
ASC89347 TEAM ASSOCIATED 16X38MM REAR SPRING (BLACK) (2) R$ 15.1
ASC89482 TEAM ASSOCIATED "LOW-B" PLATE INSERT SET R$ 7.7
ASC89549 TEAM ASSOCIATED FRONT UPPER ARM SET (RC8.2) R$ 15
ASC89550 TEAM ASSOCIATED FRONT LOWER ARM SET (RC8.2) R$ 30
ASC89551 TEAM ASSOCIATED REAR ARM SET (RC8.2) R$ 30
ASC89558 TEAM ASSOCIATED CASTER BLOCK SET (RC8.2) R$ 28
ASC89565 TEAM ASSOCIATED VERTICAL 16° CASTER BLOCK & HARDWARE SET (2) R$ 171.5
ASC89566 TEAM ASSOCIATED VERTICAL STEERING BLOCK & HARDWARE SET (2) R$ 162.2
ASC89567 TEAM ASSOCIATED VERTICAL BUSHING & PIN SET (4) R$ 37.1Preço de venda: 1000
Nenhuma proposta em andamento.
Serpent 747 / MRX5 Capricorn/Novarossi/Piccco 3PKS Byron 16% - 25% Pro Line Xceed |
- davidgirdan
- Registrado em: 16 Jul 2009, 23:00
Re: [VENDO] Peças Associated rc8/rc8.2/rc8T
oi garoto tem ainda as peças
RC8T / RC8.2 Reds / keeps off futaba 4pks byron fuel pro G2 / odonnel proline/ jconcets sweep Tires/ pro circuit AABB / GUTO |
- sotelo
Tenho sim!
Em quais você tem interesse?
- AJr.
- Registrado em: 15 Fev 2011, 21:00
Olá, tenho interesse nos itens ASC89017 gearbox, e ASC89076 camber rod ends. Qual seria o valor de envio para o Cep 78550-344? Desde já agradeço a atenção.
Savage X 4.6; RC8 RS; GT2 RS F4.6; PRO.15; Alpha Lutz .21 Stock; HK-310; 4PL Tornado 25% AKA Cityblock, Enduro Pistão RC Sinop-MT |
- Specialized
- Registrado em: 22 Mar 2013, 22:00
Amigo, tenho um RC8T, pelo que vi, todas essas peças abaixo servem, com exceção dos caster block que não entendi a diferença um e outro.
Me fale o que vc ainda tem na lista abaixo.
Qual a diferença entre esses dois ?
Grato
Grato
Mugen MBX6 Eco Mamba 2200kv
Team Associated RC8T Convertido Ezrun 2000kv
Duratrax Raze 1/8 Motor GO .21
Traxxas E-Maxx Brushless
Kyosho DMT
Traxxas Stampede VXL
Kyosho DMT
Traxxas E-maxx Ofna Ofna -- Traxxas E-maxx Sorocaba |
- edy_ms
- Registrado em: 02 Mai 2013, 23:00
Olá vc tem o tanque de combustível do rc8.2.
LOSI LOSI 350 DX3S BYRON LOSI BULDOG XTR MS RANCING TEAM |
- negrones
- Registrado em: 26 Jul 2006, 23:00
X3/ OS12TZ5/FUTABA 3PM
STRATUS 3.1 / ALPHA
STRATUS 3.1 / ALPHA
NT1 NOVA ROSSI FLASH |
- chsz_henrique
- Registrado em: 25 Ago 2011, 23:00
Amigo você tem o kit de conversão do team associeted rc8b?
- HariBreier
- Registrado em: 05 Fev 2012, 21:00
Preciso do Tanque de combustivel vc ainda possui?
xray XB9-13', XT9-14' RB k10, Reds R5T, Hyper 8P airtronics, servo Hitec, Savox MK BY MARCO AMARAL standard e bulldog proline blockade, bowtie Velofarm racing CampoGrande MS |
- marcelotga
- Registrado em: 06 Mai 2012, 23:00
Por acaso você tem uma peça parecida com essa: http://www.ebay.com/itm/X2CR-Pro-Parts- ... 20e1cc0afe
Só um Agrônomo sabe a forma certa de cuidar da terra.
X1 CRT PRÓ/ Ofna Pirate Domina 0.28 / 0.21 Hong Nor e Himoto 2,4 Ghz Pista Rei Pelé |
- vando
- Registrado em: 03 Set 2010, 23:00
Ola Amigo Tenho interece em algumas Peças ! tem fotos do ainda Tem ? Vandogpp@gmail.com
Truggy RCT8 / Serpente 811 Toro nero / GO UDP! GT3/ savox ! losi! 25% VP / 30% Original Pro line Gravatal / billycas Hobby . |
- matiaskett
- Registrado em: 07 Jul 2009, 23:00
ola ainda tem algo?se tiver manda matiaskett@yahoo.com ou 51 98676241
HPI HELL FIRE AXIAL 32 |
12 mensagens
Usuários navegando neste fórum: Nenhum usuário registrado e 16 visitantes
