Lotes de Peças para Associated RC8/RC8B/RC8.2
3 mensagens
- cardinal
- Registrado em: 14 Mar 2012, 22:00
Ofereço à venda três lotes de peças para a linha 1/8 da Associated:
LOTE A - Peças de Supensão:
Completas / Embalagem fechada:
1 x Jogo completo de amortecedores dianteiros RC8.2
1 x RC8.2 Front Arms (ASC89550)
2 x RC8.2 Front Upper Arms (ASC89549)
2 x 16mm Spring Cups (ASC89354)
3 x Camber Rod Ends (ASC89076)
2 x RC8 Steel Shock Standoffs (ASC89473)
2 x RC8 Shock Boots (ASC89356)
1 x 16 x 38mm Shock Boots (ASC89357)
1 x 16 x 32mm Shock Boots (ASC89556)
2 x Sway Bar Retainer/Eyelets (ASC89092)
1 x RC8.2 Front Spring 4.65 Blue (ASC89544)
1 x RC8.2 Rear Spring 3.75 Blue (ASC89548)
1 x 16 x 38mm Spring Bronze (ASC89349)
1 x RC8 Caster Blocks (ASC89030)
2 x RC8 Rear Hub Carrier (ASC89033)
2 x RC8 Steering Rod Ends (ASC89074)
2 x GHEA Racing Products Delrin Shock Bushing Set (GHEA2038)
3 x RC8 Shock Bushings (ASC89083)
3 x Caster Angle Bushings (ASC89032)
1 x Team Associated Shock Rod Ends (ASC89065)
1 x Steering Rack Post (ASC89014)
1 x RC8 Hinge Pin Bushings (ASC89039)
1 x RC8 Outer Hinge Pins (ASC89041)
1 x RC8.2 Aluminum Front Shock Tower (ASC89538)
1 x RC8.2 Aluminum Rear Shock Tower (ASC89539)
3 X Chassis Brace Rod Ends (ASC89077)
1 x RC8 Steering Block Bushings (ASC89029)
BÔNUS! = Peças com embalagens incompletas/abertas ou itens usados:
1 x RC8 Servo Saver Plastic (ASC89015) - faltam 2 peças
1 x RC8.2 Vertical Bushing & Pin Set (ASC89567) - faltam um pinos e uma buchas
1 x RC8 Shock Standoff Aluminum (ASC89082) - falta uma unidade
1 x 16mm Shock Rebuild Kit (ASC89352) - faltam dois diafragmas e espaçadores
1 x Eixo de amortecedor dianteiro, o-rings, tampa inferior de amortecedor
PREÇO DO LOTE A COMPLETO: R$299,00 + frete
LOTE B - Peças de Transmissão:
1 x Plastic Spur Gear 46T (ASC89519)
1 x Plastic Spur Gear 50T (ASC89521)
1 x RC8 Front CVA Axle (ASC89100)
1 x RC8 Front/Rear CVA Bone (ASC89102)
1 x RC8 Center CVA Set (ASC89099)
2 x RC8 Center CVA Rebuild (ASC89106)
1 x RC8 Diff Outdrives (ASC89118)
1 x RC8 Rear CVA Set (ASC89098) - faltando 2 dogbones
1 x Center CVA Set - GPM Racing
1 x Suporte central de diff em carbono da Xtreme Racing
3 x RC8 Body Mounts (ASC89011)
1 x Bumper dianteiro; 2 x velcro de baterias, etc
PREÇO DO LOTE B COMPLETO: R$269,00 + frete
LOTE C - Transmissão/Gearbox:
1 x Robinson Racing Associated RC8 X/Hard Spur Gear 44T (RRP2344)
1 x GPM Racing RC8 Steel Main Shaft - 1 Pair (SRC8037)
2 x GPM Racing RC8 Steel Rear Universal Swing Shaft - 1 Pair (SRC8291R)
2 x RC8.2 +3mm Center Driveshaft (ASC89560)
1 x RC8 Center CVA Rebuild (ASC89106)
3 x RC8 Rear CVA Shield & Boot (ASC89107)
1 x RC8 Aluminum Front Stub Axle (ASC89285)
2 x RC8 Front or Rear Gear Box (ASC89017)
2 x RC8 Gear Box Gasket (ASC89018)
1 x Steel Spur Gear 44T (ASC89109) - pouco usada
1 x RC8 Rear CVA Axle (ASC89101) - embalagem aberta
PREÇO DO LOTE C COMPLETO: R$299,00 + frete
***Preço especial para os 3 lotes (A+B+C) + bônus especial = R$659,00 + frete***
ATENÇÃO:
- Os lotes são vendidos FECHADOS, por favor não insista.
- Frete por conta do comprador.
- Sem trocas.
ATENÇÃO:
- Sem trocas.
Nenhuma proposta em andamento.
Base 311 | Caminho do Sal |
- cardinal
Re: Lotes de Peças para Associated RC8/RC8B/RC8.2
Anúncio PAUSADO, peças negociadas e aguardando pagamento.
- cardinal
Todas as peças VENDIDAS!
Agradeço ao fórum pelo espaço cedido, por favor fechar/trancar o tópico.
Um abraço!
Um abraço!
3 mensagens
Usuários navegando neste fórum: Nenhum usuário registrado e 22 visitantes
