[VENDO] SAKURA D3 CS - PARA DRIFT COM 2 BOLHAS !
4 mensagens
- MRS13
- Registrado em: 01 Jan 2011, 21:00
SAKURA D3 CS PARA DRIFT
ACOMPANHA 2 BOLHAS
NÃO TEM RÁDIO , RECEPTOR E BATERIA !
SEGUE ESPECIFICAÇÕES:
Motor
Can Size: 540
Turns: 8.5
RPM/v: 3983kv
Poles: 2
Sensored: Yes (Standard 6 pin harness)
Max voltage: 7.4~11.1V (2~3S)
Max Current: 33A
Max Watts: 365w
Resistance: 0.0141ohm
No Load Current: 5.8A
Shaft Size: 3.175mm
Can Diameter: 36mm
Can Length: 51.5mm
Weight: 158g
Esc
Cont. Current: 60A
Burst Current: 100A
Car Size: 1/10th
Battery: 2-3 Cell Lipo
S-BEC: 5.0V / 2A Output
Motor Type: Sensored or Sensorless Brushless (2s 6.5turn, 3s 10.5turn - or higher)
Size: 40.5 x 37.5 x 24mm
Weight: 45g
Battery Plug: Required
On/Off Switch: Yes
Reverse: Yes
Thermal Overload Protection: Yes
Battery Terminals: 14AWG size
Motor Terminals: 14AWG size
Servo
Model: HD-3001HB
Voltage: 4.8~6.0v
Speed: 0.15~0.12sec
Torque: 3.5~4.4kg/cm
Weight: 43g
Preço de venda: 799,99
ACOMPANHA 2 BOLHAS
Motor
Can Size: 540
Turns: 8.5
RPM/v: 3983kv
Poles: 2
Max Current: 33A
Max Watts: 365w
Shaft Size: 3.175mm
Can Diameter: 36mm
Can Length: 51.5mm
Weight: 158g
Esc
Cont. Current: 60A
Burst Current: 100A
Car Size: 1/10th
Weight: 45g
On/Off Switch: Yes
Reverse: Yes
Servo
Model: HD-3001HB
Voltage: 4.8~6.0v
Speed: 0.15~0.12sec
Weight: 43g
Nenhuma proposta em andamento.
Baja 5SC, FG SportsLine 08
Baja 5SC, FG SportsLine 08 Futaba 3pm Podium Originais Até ficar só a roda... PAREI... |
- MRS13
Re: [VENDO] SAKURA D3 CS - PARA DRIFT COM 2 BOLHAS !
Mais fotos.
- MRS13
BAIXANDO PARA VENDER R$ 700,00
- MRS13
VENDIDO
4 mensagens
Voltar para FR - Carros Elétricos
Usuários navegando neste fórum: Nenhum usuário registrado e 17 visitantes
