Vendo 1/16 Sportwerks Chaos
6 mensagens
- Salgado
- Registrado em: 07 Jan 2009, 21:00
Carro pouquissimo usado foi um tanque e voltou para a caixa!!.
Valor R$ 480,00
se for de SP pode retirar.
Especificaçoes:
Four-wheel independent suspension system
Oil-filled, coil-over shocks
4WD drivetrain with 3 gear differentials
Heavy-duty countersunk aluminum chassis
Full ball bearings
Micro-pin tires mounted & glued on dish wheels
Composite brake disc
40cc fuel tank
Sealed radio box
Low-profile air cleaner
3-shoe centrifugal clutch
Adjustable throttle/brake linkage system
.05 cu in racing engine with recoil starter
Oversized, machined heat-sink head
Aluminum tuned exhaust system
High-torque mini servos
27MHZ AM digital proportional radio system with steering ATV
Factory-finished body and a molded nylon high-downforce rear wing
Specifications:
Type: 4WD Nitro Buggy RTR
Scale: 1/16
Length: 10.2"
Width: 7.08"
Wheelbase: 6.7"
Chassis: Aluminum
Suspension: 4-wheel independent
Drive Train: Center shaft drive w/3 differentials
Tire Type: Micro-pin all terrain
Motor or Engine: .05 cu in with recoil starter
Radio: Sportwerks 2 channel digital proportional 27MHZ AM
Servos: Micro x 2
Shock Type: Oil-filled, coil over type
Body: Factory-finished buggy type
Ball Bearings: Complete
Fuel Tank Capacity: 1.3 oz (40cc)
Valor R$ 480,00
Especificaçoes:
Full ball bearings
40cc fuel tank
Sealed radio box
Specifications:
Scale: 1/16
Length: 10.2"
Width: 7.08"
Wheelbase: 6.7"
Chassis: Aluminum
Servos: Micro x 2
Nenhuma proposta em andamento.
- alissomalves
- Registrado em: 10 Jul 2006, 23:00
Re: Vendo 1/16 Sportwerks Chaos
apenas venda amigo...
smartech Ferrari Cy 26cc hk 2.4 ghz Podium Buggy Baja L2 SUL / BRASILIA |
- Comandante
- Registrado em: 28 Fev 2009, 22:00
6 mensagens
Voltar para FR - Carros Off Road
