VENDO DURATRAX RAZE - NOVO - R$ 1.200,00
Carros e Chassis Off Road.
Mensagempor tiagocandido » 13 Set 2009, 22:32
Vendo Buggy 1/8 Duratrax Raze na caixa lacrado.
Bolha na cor ROXA.
O produto foi importado com intenção de venda.
VALOR: R$ 1.200,00.
Estou em Curitiba (CEP 80330-120) e posso entregar em mãos.
Para demais cidades calculo o frete após lance.
Segue as especificações do Automodelo (conforme fabricante):
FEATURES: Chassis: 0.12" (3mm) thick aluminum, anodized blue in color with
molded plastic chassis side guards and built-in transponder mount
(transponder not included)
Drive: Four wheel shaft drive
Radio: Duratrax by Futaba FM pistol grip/two servos, micro receiver
with 3rd channel for transponder use, servo reverse, steering
and throttle trims and dual rate, transmitter does not have charge
jack
Radio Box: Sealed
Engine: Supertigre G-27CX .27 cu in (4.4cc) ABC cylinder and liner
construction, recoil starter, glow plug, dual ball bearing
supported crankshaft, slide valve carburetor, 2.5 hp at 30,000 RPM
Exhaust: Aluminum tuned pipe
Engine Mount: Aluminum, adjustable
Fuel Tank: 4.2oz (125cc), flip top cap
Clutch: 3-shoe racing type
Ball Bearings: Full set, 18 total
Shocks: Oil-filled with aluminum bodies, coil-over springs and
multiple shock mounting and camber positions, 4mm front shock
tower, 3mm rear shock tower
Main Gear: 46 tooth, hardened steel
Differentials: Three, sealed adjustable with metal internal spider
gears, front and rear diff cases remove easily for maintenance
Brakes: Dual disc with adjustable bias
Tires: 4.6" (117mm) diameter, 1.6" (40mm) wide with foam inserts and
off-road tread
Wheels: 6-spoke 3.5" (89mm) diameter, 1.6" (40mm) wide
Body: Painted with decals applied
Bumpers: Front, hardened plastic
Suspension: Four wheel independent
Caster: Adjustable, caster/toe-in refers to the angle of the front
suspension when viewed from the side of the car in relation to the
chassis, 2° and 3° rear toe-in blocks included
Camber: Adjustable, camber refers to the angle of the tops of the
tires from vertical when viewed from front or behind vehicle
chassis
Steering: Dual bell crank with servo saver and metal front steering
knuckles, 17mm drive hex is compatible with other 1/8 scale models
Glow Starter: C size
Fuel Bottle: 8.4oz (250cc)
INCLUDES: Duratrax 1/8 Raze scale buggy with Supertigre G27CX engine w/pull-
starter, glow plug, tires, foam inserts, wheels Futaba FM pistol
grip radio system, two servos, glow starter, fuel bottle,
13 tooth clutch bell, 46 tooth steel spur gear, aluminum bodied
shocks, photo-illustrated instruction manual, instructional DVD
REQUIRES: Radio Batteries: (8) AA size
C-Cell Battery: For glow starter
Fuel: 2-cycle glow fuel with 20% nitromethane, 16% lubricant-
Most of the fuels we carry meet or exceed the lubricant content
required for optimum performance and maximum engine life. In the
past, the conventional lubricant content used in fuel was 18%. But
with new advanced technologies, fuels like Red Alert and O'Donnell
for example, have a better quality of lubricants even though the
percentages of lubricant content are lower. These high-tech
lubricants provide exceptional cooling and protection.
SPECS: Vehicle-
Length: 18.5" (470mm)
Width: 11.7" (298mm)
Height: 7.7" (195mm)
Weight: 7.7 lbs (3.5kg) approx.
Wheelbase: 12.5" (317mm)
Front Tread: 10.1" (258mm)
Rear Tread: 10.6 (270mm) wheels on-center side-to-side
Front Track: 11.5" (292mm)
Rear Track: 12" (304mm) outer edges of wheels
Ground Clearance: 1.8" (45mm)
Body-
Length: 14" (355mm)
Width: 8.5" (216mm)
Height: 4.25" (108mm)
Proposta Aceita A Proposta (nº 226542) do usuário Sandro.Martins (1 pts) foi aceita! O usuário tiagocandido deu uma qualificação POSITIVA para o usuário Sandro.Martins. O usuário Sandro.Martins deu uma qualificação POSITIVA para o usuário tiagocandido.
Registrado em: 17 Nov 2008, 21:00
Re: VENDO DURATRAX RAZE - NOVO - R$ 1.200,00
Mensagempor DiegoFusion » 14 Set 2009, 03:08
INTERESSA TROCA?
TENHO UM TRAXXAS NITRO RUSTLER ZERADAO!!
ABRASSS
 RRR EVO WC / TB02      PLUS 3T / STOCK      JR Xr2i / FUTABA      SIDEWINGER / NICD      NSX / MERCEDES DTM      ALPHA/JACO      RC-SHOW/MARTCENTER
Mensagempor tiagocandido » 14 Set 2009, 10:40
só venda
Registrado em: 19 Set 2009, 23:00
Mensagempor Sandro.Martins » 20 Set 2009, 22:19
Estou em Londrina, tenho interesse, estava olhando na Deltamodelismo. Voce manda por sedex a cobrar? Se nao quais as opcoes de pagamento?
O que falta no carro para ele andar perfeitamente? Vi que faltam baterias quais sao estas baterias? São comuns?
Caso tenha algum parente por aqui posso ir buscar na casa deste e pagar em maos. Aguardo retorno.
Iniciante
 Raze      Super tigre 27      Duratrax      Duratrax      ----      -----
Mensagempor tiagocandido » 21 Set 2009, 10:28
Para andar você precisará de 12 pilhas AA (aquela comum). Recomendo comprar pilhas recarregáveis. ;)
Olá, se você tiver parente aqui em Curitiba posso entregar em mãos sim!
O frete Curitiba/Londrina vi no site dos correios que fica por R$ 36,00 através de PAC e R$ 45,00 através de Sedex.
Quanto a situação de estar preocupado com a entrega, pode ficar tranquilo. Sou automodelista há 5 anos. Já fiz outras vendas aqui no site e tenho muitas postagem, artigos e conhecidos no site.
Mensagempor Sandro.Martins » 22 Set 2009, 10:33
Ok, voce pode me mandar por sedex pago?
PropostaNegociação:
Iniciante
Voltar para FR - Carros Off Road
Usuários navegando neste fórum: Nenhum usuário registrado e 20 visitantes
