[VENDO] Feirão de peças Losi 8ight 2.0RR
49 mensagens
• Página 1 de 4 • 1, 2, 3, 4
- nbrancalhaojr
- Registrado em: 27 Set 2009, 23:00
Feirao de peças, preço da Amainhobbies x dolar do dia + frete
Lojinha Losi
-TLR3501 - Diff shaft set, alum
-LOSA6540 (2) - turnbuckles 5x60mm w/ ends
-LOSA6541 (2) - turnbuckles 5x68mm w/ ends
-LOSA5426 - 15mm shock boot set (2)
-LOSA3523 - F/R CV driveshaft coupling set (2)
-LOSA5421 - 15mm shock caps bottom
-LOSA5429 - Shock o-ring set
-LOSA9106 - clutch pins & hardware (2)
-LOSA3508 - F/R Diff pinion gear (2)
-LOSA4431 - Hinge pin brace cover set
-LOSA5452 - 15mm springs 2.3" x 4.7 green
-LOSA6500 - hinge pins 4x66mm TiN
-LOSA1744 - Front hinge pin brace set
-LOSA5435 - 15mm shock ends, cups, bushing
-LOSA6046 - 4mm rod end set
-LOSA5438 - shock standoff set
-LOSA6050 - steering ball set 6.8mm
-LOSA9103 - Clutch nut & hardware
-LOSA3502 - diff gear & shaft set
-LOSA3522 - F/R Driveshaft axles
-LOSA1703 - Front suspension arm set
-LOSA6057 - Inserts, camber stand offs
-LOSA1791 - Front suspension arm bushings
-LOSA6503 - outer hinge pins 3.5mm
-LOSA6047 - 5mm rod end set
-LOSA6215 - #4 narrow washers
-LOSA6350 - #4 and 1/8" hardened washers
-LOSA6302 - 5-40 locking nuts, steel
-LOSA4452 - Gear box shims
-LOSA4424 - body posts& tank mounts
-LOSA4426 - Chassis specer/cap set
-LOSA9163 - fuel tank cap, spring & seal
-LOSA4412 - steering rack set
-LOSA6045 - HD Steering link set
-LOSA4435 - wing mount set
-LOSA1707 - front spindles
-LOSA4424 - Body posts & tank mounts
-LOSA4422 - FR bumper, tank, filter guard
-LOSA4420 - Center diff Mount & brace set
-LOSA4427 - Front Gearbox set
-LOSA4450 - rear gearbox set
-LOSA3505 - Diffential seal set
-LOSA5420 - 15mm shock caps top
-LOSA9107 - clutch shoes composite (6)
-LOSA9108 - clutch shoes alu (2)
-LOSA9165 - tuned pipe mount & hardware
-LOSA99032 - servo arm FUT
-LOSA99031 - servo arm KO/AIR
-DER-110-L - DE Racing Losi 8ght buggy mud guards
-LOSA5226 - silicone shock oil 40wt
-LOSA5213 - silicone shock oil, 22.5wt
Preço de venda: 1,00
Lojinha Losi
A Proposta (nº 477675) do usuário flaviobaccelli (14 pts) foi aceita! O usuário nbrancalhaojr deu uma qualificação POSITIVA para o usuário flaviobaccelli. O usuário flaviobaccelli deu uma qualificação POSITIVA para o usuário nbrancalhaojr.
A Proposta (nº 478915) do usuário flaviobaccelli (14 pts) foi aceita! O usuário flaviobaccelli deu uma qualificação POSITIVA para o usuário nbrancalhaojr. O usuário nbrancalhaojr deu uma qualificação POSITIVA para o usuário flaviobaccelli.
A Proposta (nº 480489) do usuário cyberwisk (16 pts) foi aceita! O usuário nbrancalhaojr deu uma qualificação POSITIVA para o usuário cyberwisk.
Proposta de rodrigow (0 pts) aguardando aceitação. Clique aqui ver a proposta.
Obs: Qualificações Neutras normalmente significam que o negócio foi cancelado.
- flaviobaccelli
- Registrado em: 12 Mar 2012, 22:00
Re: [VENDO] Feirão de peças Losi 8ight 2.0RR
Bom dia amigo! Quero comprar as seguintes pecas: Tlr3501, Losa5426 x 02, 3523, 3501, 6046, 6503, 4424, 4426, 3505, 3502. Somando pelos preços da Amain fica em $72,85. Veja o que pode fazer pra mim nessas pecas e calcule, por favor, o frete via Sedex e Pac para o CEP: 38400-670. Aguardo retorno. Grande abraço.
Negociação:
- nbrancalhaojr
Bom dia,
Você se refere a outra 3501?
Só tenho uma, a TLR3501.
Pode fechar pelo valor da Amain x 2,05 + R$17,00 via PAC ou R$40,00 via Sedex.
Só confirma essa 3501 por favor.
- flaviobaccelli
Bom dia! É isso mesmo amigo, fiz confusão, estou me referindo a Tlr3501. O valor das pecas entao somaram $69,16 x 2,05 = R$141,78 + R$17,00 (Pac) = 158,78. Confirma se esta tudo certo e me da um Ok. Me envia por MP seus dados bancários que lhe envio o endereço para envio das pecas. No aguardo.
- nbrancalhaojr
Algumas peças foram vendidas, segue relação atualizada
-LOSA6541 (2) - turnbuckles 5x68mm w/ end.
- nbrancalhaojr
Atualizando a relação mais uma vez, mais algumas peças vendidas.
-LOSA6540 - turnbuckles 5x60mm w/ ends
-LOSA6541 - turnbuckles 5x68mm w/ end.
- MISTER-XIS
- Registrado em: 06 Set 2008, 23:00
Galera tudo zero! perfeito!!! apesar do post já está fechado ele ainda tem alguns itens!
Vendedor recomendado
TeamLosi 1.0 PRO. Novarossi TORO NERO TEAM. Airtronics M11 MK 25% extra Team Losi eigth PRO-LINE A.S.A - São Sebastião-SP |
- nbrancalhaojr
Obrigado Tarcísio!
Pessoal, tenho lipos para RX também, embreagens, pinhões, parafusos, etc.
- flaviobaccelli
Bom dia Nelson! As lipos que tem para Rx são Protek?!?! O q mais tem aí nesse etc? Grande abraço.
- nbrancalhaojr
Bom dia,
Sim, tenho 5 lipos protek, sendo todas em perfeito funcionamento.
2 com 1 ano de uso, 2 com 2 corridas de uso, 1 lacrada.
Tenho as caixas da Losi de parafusos, reparo de amortecedor e reparo de embreagem, usadas, mas com muitas coisas:
http://www.amainhobbies.com/product_inf ... rtment-Box
http://www.amainhobbies.com/product_inf ... HT-8IGHT-T
http://www.amainhobbies.com/product_inf ... ervice-Box
Jogo de rolamentos do carro tenho também, novos, mas sem embalagem acho.
Jogo de amortecedores buggy usados, molas de várias cores e comprimentos novas e usadas sem ebalagem, barras estabilizadoras, que lembre de cabeça agora.
- nbrancalhaojr
Tenho os links "turnbuckles" originais novos também, sem embalagens.
- flaviobaccelli
Nelson, mandei MP!
Negociação:
- nbrancalhaojr
Atualizando:
-LOSA9107 - clutch shoes composite (4)
- nbrancalhaojr
Encontrei mais algumas no fundo das gavetas
-LOSA1701 - Front suspension arm bushings
-DER-110-L - DE Racing Losi 8ight buggy mud guards
-LOSA5224 - silicone shock oil 30wt
-LOSA 5225 - silicone shock oil, 35wt
-LOSA5434 - 15mm shock ends, cups, bushing
-LOSA9349 - rear exhaust manifold springs
Usada em excelente estado: radio tray montado
Jogo de turnbuckles
Coroas dos 3 diffs
Jogo de turnbuckles
Coroas dos 3 diffs
- nbrancalhaojr
Incluindo alguns itens que chegaram.
-LOSA5214 - silicone shock oil 27.5wt
-LOSA5216 - silicone shock oil 37.5wt
-TKR4435 - Tekno RC adjustable wing mount
49 mensagens
Usuários navegando neste fórum: Nenhum usuário registrado e 16 visitantes
