Peças TLR 3.0
Peças para carros. Todos os tipos. (Coroas, Pinhões, Correias, Dogbones, Diferenciais, Molas, Amortecedores, Bandejas, etc)
Registrado em: 30 Out 2011, 21:00
Peças TLR 3.0
Mensagempor PhBuggy » 04 Jan 2015, 15:42
Peças novas (zerada):
TLR244011 - Team Losi Racing 4x66mm TiCn Inner Hinge Pin (2);
TLR242003 - Team Losi Racing Coupler Outdrive;
TLR244000 - Team Losi Racing Front Suspension Arm Set;
TLR244008 - Team Losi Racing Rear Suspension Arm Set;
TLR342000 - Team Losi Racing Rear Dogbone (2) (Traseiro - 8B 3.0);
TLR240001 - Team Losi Racing 8IGHT 3.0 Wing (Black);
TLR243007 - Team Losi Racing 4x54mm TiCn Front Shock Shaft;
TLR4401 - Team Losi Racing "Gen III" Radio Tray;
TLR243008 - Team Losi Racing 4x59.5mm TiCn Rear Shock Shaft;
TLR340001 - Team Losi Racing 8IGHT 3.0 Cab Forward Body (Clear);1 LOSA 4435 - Losi Wing Mount Set - 2;
TLR243019 - Team Losi Racing Rear 16mm Shock Spring Set (Silver -3.6 Rate);
TLR3538 - Team Losi Racing Aluminum Covered 17mm Wheel Nuts (Hard Anodized) (4);
TLR240001 - Wing, Black 8IGHT Buggy 3.0;
TLR243002 - 16mm Shock Body Set, Front (2);
TLR243003 - Team Losi Racing 16mm Rear Shock Body (2);
TLR243018 - Team Losi Racing 16mm Rear Shock Spring Set (Red - 3.4 Rate) (2);
TLR243016 - Team Losi Racing 16mm Front Shock Spring Set (Green - 4.8 Rate) (2);
TLR243019 - Team Losi Racing Rear 16mm Shock Spring Set (Silver -3.6 Rate) (2);
LOSA1756 - Losi Adjustable Hinge Pin Brace Insert Set;
LOSA 9125 - Losi 12T High Endurance Clutch Bell;
LOSA6046 - Losi 4mm Rod End Set;
LOSA6056 - Losi 6.8mm Suspension Balls (4);
LOSA3501 - Losi 6x11x.2mm Differential Shims;
LOSA6306 - Losi 4-40 Aluminum Mini Nuts (10);
Team Losi Racing 8IGHT 2.0 Cab Forward Body EU (Clear);
LOSA9106 - Losi 4 Shoe Clutch Pin & Hardware Set ;
LOSA4420 - Losi Center Differential Mount & Brace Set;
LOSA3510 - Losi Rear Differential Ring Gear;
LOSA1731 - Losi Rear Hub Carriers;
LOSA99424 - Losi Starter Drive Belt;
LOSA99421 - Losi Starter Wheel;
LOSA9102 - Losi 4 Shoe Steel Flywheel & Collet (8IGHT/8IGHT-T);
LOSA9105 - Losi Aluminum 4 Shoe Flywheel & Collet Set (8IGHT);
LOSA 6287 - Losi 4-40 x 1 1/4 Cap Head Screws (6);
LOSA6050 - Losi 6.8mm Steering Ball Set;
LOSA6227 - Losi 4-40x1/8” Hardened Set Screws;
LOSA6249 - Losi 4-40x0.150" Flat Head Screw (10);
LOSA6384 - Losi 5-40x20mm Left Hand Thread Button Head Screw (10);
LOSA4435 - Losi Wing Mount Set;
DER 110-10 DE Racing Mud Guard Set (TEN-T/SCTE/810);
CRP 0011 Competition Suspension Losi 8IGHT EX Performance Shock O-Rings (8);
LOSA9162 - Losi Fuel Tank (8IGHT 2.0) ;
LOSA4446 - Losi Steering Bellcrank & Servo Saver Set;
LOSA4413 - Losi Front Chassis Brace Set;
LOSA4408 - Losi Steering Post Set;
LOSA3556 - Losi 48T Lightweight Center Differential Spur Gear;
LOSA3505 - Differential Seal Set: 8B,8T, LST, XXL, MB;
LOSA9108 - Losi Aluminum Clutch Shoes (2);
LOSA3532 - Losi Wheel Hexes + 2mm Wider (4) (8IGHT/8IGHT-T);
LOSA9113 - Losi 036” 30 Deg Clutch Springs (Green);
LOSA 9114 - Losi 040” 25 Degree Clutch Springs (Gold);
LOSA9112 - Losi .036” 25 Degree Clutch Springs (Black);
LOSA5438 - Losi Shock Standoff (1);
LOSA9154 - Losi Engine Mount Set;
LOSA3522 - Losi F/R CV Driveshaft Axles (1)
jogo de rolamento completo;
cx de parafuso completa;
Diff central completo + freio + Mount & Brace Set + Filter Guard;
Peças semi-novas (Up Grade)
TLR244021 - Team Losi Racing 8IGHT Aluminum Servo Saver Top;
LOSA4440 - Losi 8IGHT Aluminum Front Top Brace;
PTK-7805 - ProTek R/C Aluminum Servo Horn (25T-Futaba/Orion/Savox/ProTek);
TLR1557 - Team Losi Racing Aluminum Servo Horn (25T-Futaba/Orion/Savox/ACE) (TLR 22);
LOSA4417 - Losi Aluminum Rear Chassis Brace;
TLR3510 - Team Losi Racing Front Overdrive Gear Set (8B);
LNS7380 - Lunsford "Quick Tune" Losi 8ight/8T Titanium Shock Mounts (4);
LOSB5011 - Losi Fuel Tank Lid Pull Set (Fluorescent Yellow) (2);
LOSA9155 - Losi Quick Change Engine Mount Set;
LOSA4444 - Losi Aluminum Split Center Differential Mount;
LOSA1732 - Losi Aluminum Rear Hub Carriers (2.0);
LNS7380 - Lunsford "Quick Tune" Losi 8ight/8T Titanium Shock Mounts;
RBD02013-007 - RB Products "A.D.S." Automatic Damping System Set (Losi 8IGHT 3.0).
Peças Usadas:
Tenho muita coisa.... molas preta / verde / cinza dos amortecedores, chassis da BCE, sapatas (alumínio e carbono), parafusos, porcas, dogbone, 1 frente completa (sem torre), 1 central completa, 1 traseira completa (sem torre); rolamentos, flywhweel de alumínio e de ferro, sino de 13T, 14T e 12T, coroa central de 45T / 46T / 48T, Losi Front Center Universal Driveshaft, Losi Drive Pin Set, Losi 6x11x.2mm Differential Shims, Team Losi Racing Aluminum Differential Shaft Set (6)
Ferramentas (Semi-novas)
TLR99102 - Turnbuckle Wrench;
LOSA99172 - Losi Camber Gauge;
TLR99101 - Shock Shaft Pliers;
LOSA99150 - Losi 4 Piece Race Nut Driver Set (US Sizes);
LOSA 99104 - Losi Race Wrench: US 4 pc Set.
VALOR TOTAL DE R$ 2.000,00
Nenhuma proposta em andamento.
Raphael Oliveira - PH
Campinas / SP
Tel. e ZapZap (19) 99211-7059
 Mugen      OS      M12S      Byron      Mion Bolhas      PL      Paulinia Racing
Registrado em: 22 Abr 2013, 23:00
Re: Peças TLR 3.0
Mensagempor Lewis » 19 Jan 2015, 21:53
Tem pinhão A3508?
Persistência e determinação...Por si só, serão decisivas....
 Losi 8ight 2.0 / Losi 8ight RR      Go Engine / REDS R5      Spektrum DX4S      Byron 20% / VP Power 25%      Losi Proline / Losi Original      Proline / AKA      Extra / Pelezão / Dust Raising
Registrado em: 06 Mai 2012, 23:00
Re: Peças TLR 3.0
Mensagempor marcelotga » 28 Jan 2015, 09:41
Você tem alguma Arm Ball a venda? Se sim qual a medida?
Peça idêntica a essa: http://www.ebay.com/itm/X2CR-Pro-Parts- ... 20e1cc0afe .
Só um Agrônomo sabe a forma certa de cuidar da terra.
 X1 CRT PRÓ/ Ofna Pirate Domina      0.28 / 0.21      Hong Nor e Himoto 2,4 Ghz      Pista Rei Pelé
Registrado em: 06 Mar 2013, 22:00
Re: Peças TLR 3.0
Mensagempor charliecwb » 11 Fev 2015, 16:02
Quanto faz:
sino de 13T
Charles Saad
 Losi 8ight-T 2.0      Losi 350      Spektrum DX3S      O'Donnel      AKA      BullRacing
Registrado em: 20 Fev 2015, 22:32
Re: Peças TLR 3.0
Mensagempor Magaiver91 » 23 Set 2015, 14:26
tenho interesse em comprar. favor entrar em contato
guilherme.maciel.vieira@gmail.com
031-9582-1443
 truggy 3.0 losi      OS SPEED 21XZ-B SEPC II      DX3R      Byron      AKA      Uba Racing
Voltar para FR - Peças
