Turnigy TZ4 AWD 1/28 Mini Touring Car
The TZ4 AWD mini touring car is a mini size RC car with a Big guy attitude…The new Touring MINI-Q chassis has all the features of its bigger 1/10 scale brother from tunable suspension and chassis set up to swappable Lexan bodies and adjustable wheelbase.
Performance is unprecedented for its size with shaft drive AWD and front and rear diffs, full ball bearings and Carbon chassis. The 2 cell 650mAh Li-Poly Battery provides ample run time and there is a Full list of hop-up and replacement parts, and with the removable body posts and adjustable wheel base chassis the Turnigy MINI Q is Compatible with a host of Kyosho Mini-Z body shells wheels and tires!
You just need any HobbyKing GT series radio or FLYSKY compatible Protocol radio to “Bind and Drive” the TZ4, and to commandeer a room or driveway to hone your ninja like driving skills and an all-out need for speed!!!
Features:
• Carbon Chassis
• Rubber Tires
• Full ball bearings through-out
• 5g Servo
• 130 Brushed motor
• Full proportional control 2.4ghz Receiver
• 3 in 1 Receiver, ESC combo
• 650mAh 7.4v 2 cell Li-Poly battery
• Polycarbonate body shell
• Kyosho Mini-Z compatibility with body shells and wheels/tires
• Included Charger
Specs:
Motor: 130 class
Weight: 164g with battery
Wheelbase: 104mm-110mm adjustable
Width: 70mm Adjustable with Rims
Requires:
Any HobbyKing GT series car or FlySky protocol Transmitter
Site: http://www.hobbyking.com/hobbyking/stor ... _BND_.html
Voltar para “Micros e Minis”
