MUNDIAL 2008 PORTUGAL
Re: MUNDIAL 2008 PORTUGAL
É KIOSHO CAMPEÃO 2008
DANIELE É CAMPEÃO
DANIELE É CAMPEÃO
wagnerrs
NÃO PERDE MAIS
DOBRADINHA DE RRR
wagnerrs
KYXOXÃO CAMPEÃO 2008.
AGORA É COMPRAR O RRR WCTE 2008
# Nr Vehicle Pilot Club Country i T Laps Laptime Absoluttime Besttime Mediumtime Forecast
1 3 Daniele Ielasi IT 184 00:20.047 01:00:17.246 00:18.888 00:19.499 184
2 2 Chris Tosolini USA 183 00:19.191 01:00:05.849 00:18.677 00:19.101 183
3 10 Martin Hudy SK 183 00:19.322 01:00:08.242 00:18.837 00:19.178 183
4 8 Paul Lemieux USA 183 00:19.725 01:00:15.271 00:18.496 00:19.987 183
5 1 Jilles Groskamp NL 182 00:19.145 01:00:06.295 00:18.689 00:19.112 182
6 4 Tironi Francesco IT 182 00:20.147 01:00:18.076 00:18.826 00:20.052 182
7 5 Martin Christensen DNK 172 00:19.054 00:57:18.047 00:18.801 00:20.424 180
8 9 Adrien Bertin LUX 139 00:19.142 00:52:43.743 00:18.917 00:19.087 162
9 6 Teemu Leino FIN 112 00:18.896 00:37:27.985 00:18.711 00:19.976 180
10 7 Balestri Dario IT 52 00:19.396 00:25:17.506 00:19.195 00:19.689 158
MAS O NOME DESSA FINAL É PAUL LEMIAUX....
ELE TAVA NA FRENTE LONGE... QUEBRO... FICO 3 VOLTAS ATRAS... E TERMINA EM 4º
wagnerrs
O nome é de quem ganhou DANIELE. O tosoline mesmo tava andando mais forte que ele e se tivesse mais alguns minutos de corrida acho que passaria o Daniele.Mindu escreveu:MAS O NOME DESSA FINAL É PAUL LEMIAUX....
DANIELE IELASI IT Kyosho V-ONE RRR - PICCO IDM
CAMPEÃO MUNDIAL 200mm 2008, salvo algum protesto...hehe
Editado pela última vez por wagnerrs em 16 Ago 2008, 18:53, em um total de 1 vez.
wagnerrs
Final is GO!
Lap 1 - Groskamp leads from Tironi. Tosolini spins out and last
1 minute - Balestri gets Stop & Go for hitting Leino
2 minutes - Groskamp clear lead from Lemieux
3 minutes - Top 4 - Groskamp, Lemieux, Leino and Tironi. Tosolini up to 6th.
3:30 minutes - Tosolini hits Bertin. Gets Stop & Go.
4:30 minutes - Groskamp still leads from Lemieux.
5:30 minutes - After first Pitstops. Groskamp extends lead.
6 minutes - Balestri out. Front corner off after getting collected following a spin.
7 minutes - Order is Groskamp, Lemieux, Leino, Tironi
7:30 minutes - Groskamp makes mistake, Lemieux leads.
9 minutes - Lemieux has comfortable lead from Groskamp and Leino.
10 minutes - Tosolini and Groskamp run out of fuel.
11 minutes - After second pit stops - Lemieux, Leino, Groskamp and Bertin. Top 8 on lead lap.
12 minutes - Order is Lemieux, Leino, Groskamp, Bertin, Tironi, Hudy, Ielasi, Christensen, Tosolini & Balestri (out).
13:30 minutes - Balestri rejoins race.
15 minutes - Bertin stalls during pitstop
16 minutes - Leino’s car stops on track
17 minutes - Leader Lemieux about to lap Groskamp who is second!
18 minutes - Order is Lemieux, Groskamp, Hudy, Tironi, Ielasi, Christensen, Bertin, Tosolini, Leino & Balestri.
19:30 minutes - Groskamp stalls after his pit stop.
20 minutes - Lemieux has lapped entire field. Hudy second. Groskamp back running - now 6th.
22 minutes - Lemieux about to put Hudy who is second 2 laps down!
24:30 minutes - Order is Lemieux, Hudy, Ielasi, Tironi, Christensen, Groskamp, Bertin, Tosolini, Leino & Balestri.
26 minutes - Lemieux 2 laps up on the entire field! Balestri crashes again.
27 minutes - Groskamp closing on Tironi for fifth.
28 minutes - Lemieux doing tyre change.
29 minutes - Lemieux’s car stalls - trouble restarting but he is back on track
30 minutes - Half way and Hudy leads from Ielasi and Christensen. Lemieux 9th.
32 minutes - Order Hudy, Ielasi, Christensen, Groskamp, Tironi, Tosolini, Bertin, Leino, Lemieux and Balestri (out).
34 minutes - Groskamp stalls again after pit stop. Pit crew adjust ideal.
35 minutes - Order is Ielasi, Hudy, Christensen, Tironi, Tosolini, Leino, Groskamp, Bertin, Lemieux.
36 minutes - Lemieux running super fast laps but 2 laps down running 8th but he has fresh tyres.
38 minutes - Leino crashes and damages car.
39 minutes - Bertin stops on track.
42 minutes - Bertin changing engine!
44 minutes - Ielasi leading from Hudy and Christensen. Lemieux is 7th now one lap down.
48 minutes - Hudy back in lead from Ielasi. Lemieux storming through the field and 6th.
52 minutes - Hudy leads from Ielasi
53 minutes - Tironi rolls
55 minutes - Tosolini passes Hudy for second
57 minutes - Ielasi leads bu almost a full lap
57:30 minutes - Christensen stops on track
58 minutes - Order Ielasi, Tosolini, Hudy, Lemieux, Groskamp, Tironi, Christensen, Bertin
60 minutes - DANIELE Ielasi is World Champion
wagnerrs
Ta ai "O CARA"
Ta ai "O CARRO"
Ta ai "O CARRO"
Agora vai ficar dificil pra Kiosho... pois ele não andou de EVO 2, e o carro dele tem tanque de NT1...
E agora como vai se chamar???
REALMENTE ESSE É O CARA DE 2008
wagnerrs
Vai ter que fazer uma cruza de RRR com tanke de Xray e Radio Plate da Capricorn...heauehuaeae
Pelas fotos da para ver que ele usou isso
79,12€
29,04€
43,12€
43,12€
24,20€
Provavelmente a Centax também deve ser da Capricorn
104,72€
79,12€
29,04€
43,12€
43,12€
24,20€
104,72€
Editado pela última vez por wagnerrs em 16 Ago 2008, 18:12, em um total de 4 vezes.
Pah fiquei de cara com o preço do EVO 2.... U$ 345,00 na Mush
wagnerrs
Ta barato o EVO 2 mesmo.
O verdadeiro WCTE tem que ter essas peças que mostrei acima.... boa parte das peças do carro campeão são Capricorn.
Uma saida para a Kyosho seria uma parceria com a Capricorn para lançar o V-One RRR WC 2008 usando os opcionais dessa fabrica. O problema maior é o tanke de NT1 que é concorrente. hehehe
Ahhhh mais um ano pra encher o saco da galera do G4 aqui.. KKKKKKK
- kenediquequi
è gente,,,o Ielasi ganhou,,,,,
O cara nao e piloto de fabrica
O cara nao usou o chassi m ais novo da Kyosho
E o grande detalhje,,,ele andou de motor PICCO,,,,,motor que todo mundo fala que nao presta o cara vai la e simplesmente vai direto pra final nos TOP 4,,,,,,, .
Sempre disse que motor PICCO anda muito primcipalmente esse EVO3,,,,,que tem nas versoes LRP SPEC 4,,,,,,JL RED DOT EVO4,,,,,,,MEGA ZX12 DSII,,,,,
Claro que ele pode neo ter a mesma vida util dos novarossi,,,mas em comparacao a preco, vale e muito a pena, pois anda muito bem....
Team Driver Pursuit Racing.
É, pelo que pude acompanhar aqui, os tempos de volta nao foram assim superiores, outros Kyosho tiveram tempos bem melhores, más a constancia do conjunto parece ter sido muito boa. Gosto muito dos Rossi, é claro que existem por ai grandes motores e acho sinceramente como a OS entrou este ano queimando dinheiro lançando motores novos, podem se preparar para vir mais um forte candidato aos mundiais de 200mm em breve.
