lombada pecas rc8t
lombada pecas rc8t
lombada rc8t
Re: lombada pecas rc8t
15 -velas o.s p3= 25,00
7 -velas o.s p6=25,00
2 -velas o.s p8=25,00
2 -velas o.s p7=25,00
4-6v 1500mh ni-mh receiver pack dynamite - 30,00 usado
1-ASC89028 Team Associated Steering Blocks (RC8/RC8T)
1- jogo rolamentos ASC89160 Team Associated Drive train Bearing Set (RC8)
1-ASC89364 Associated RC8T Front CVA Set 90,00 reais
1-ASC89365 Associated RC8T Rear CVA Set 90,00 reais
1-Team Associated Anti-Roll Bar Set (RC8) [ASC89086] 60,00
1- ASC89028 Team Associated Steering Blocks (RC8/RC8T) 60,00
1- ASC89372 Associated RC8T 50T Spur Gear 50,00
1-ASC89374 Associated RC8T 54T Spur Gear 50,00
2- ASC89131 Team Associated Updated Fuel Tank (RC8) 50,00
1- ASC89376 Team Associated RC8T 13T Clutchbell 35,00
1- ASC89120 Team Associated Differential Gears, Washers, and Pins 25,00
1- ASC89029 Team Associated Steering Block Bushings (RC8) 22,00
1-Rear Arms - rc8t SKU: ASC89311 30,00
1-Front Arms - rc8t SKU: ASC89310 30,00
1-Front Shock Boots - rc8t SKU: ASC89356 20,00
1-Rear Shock Boots - rc8t SKU: ASC89357 20,00
1-ASC89017 Team Associated Front or Rear Gear Box 20,00
1- ASC89316 Associated RC8T Shock Risers w/Pins 15,00
1- ASC89006 Team Associated Servo Mount/Spacers 15,00
1- ASC89076 Team Associated Camber Rod Ends (RC8) 15,00
1-ASC89033 Team Associated Hub Carrier (RC8) (2) 15,00
2-ASC89107 Team Associated Rear CVA Shield & Boot (RC8) 15,00
1-ASC89133 Team Associated Clutch Springs 1.0 (RC8) (3) 10,00
1- ASC89325 Associated RC8T Fuel Line Clips 10,00
1-ASC89056 Associated Internal Snap Ring (RC8) 5,00
1- ASC89148 Team Associated Clutch Bell Shim Set (RC8) 10,00
1-ASC89128 Team Associated Fuel Tank Mount (RC8) (2) 10,00
1-ASC89074 Team Associated Steering Rod Ends (RC8) 10,00
1- ASC89065 Team Associated Shock Rod Ends (RC8) (4) 15,00
1- ASC89030 Team Associated Caster Blocks (RC8) (2) 20,00
1-ASC89064 Team Associated Shock Rebuild Kit (RC8) 25,00
1-ASC89310 Team Associated Upper & Lower Front Arm Set 35,00
1-ASC89311 Team Associated Rear Arms 35,00
1- ASC89129 Team Associated Engine Mount (RC8) 50,00
1- ASC89134 Team Associated Clutch Shoes With Shim (RC8) 60,00
1-ASC89146 Team Associated Factory Team Hard Aluminum Clutch Shoes (3) 50,00
1- ASC89366 Associated RC8T Front/Rear CVA Bones 60,00
10-grp Crank Case O-Ring Set - .21/.28 Tuned Buggy 10,00
4-PRO1140-11 Pro-Line White Pre-Mounted Bow Tie LPR Standard Offset M2 Monster Truck Tires (2) 100,00
4-PRO1141-11 Pro-Line White Pre-Mounted Crime Fighter LPR Standard Offset M2 Monster Truck Tires (2) 100,00
oil silicone -200 300 600 700 3.000 4.000 6.000 10.000 30.000 100.000 muguen e r/c pilot = 15,00
2-o.s OSM72413000 O.S. Complete Super 203 Air Cleaner Assembly 80,00
2-SPM1410 Spektrum Nitro Telemetry Sensor Pack (3) 40,00
1-ASC89262 Team Associated Molded Shock Caps (4) (RC8RS) 15,00
1- ASC89062 Team Associated Shock Spring Cup (RC8) 10,00
1-RDLIT02AW RD Logics Infrared Thermometer w/ Laser Pointer 120,00
1-dremel 150,00
1-Rivergate 120V AC to 45A DC Bulldog Power Supply RDC45 600,00
1-Trinity I-Balance LiPo Battery Manager Charger #22006 600,00
1-GPMM3153 Great Planes Triton 2 DC Computer Charger 200,00
cel 78573412 ou 83760110
flavio@mixjeans.com.br
1-dremel 150,00
2-4 x FUTM0554 Futaba BLS352 Digital Brushless High Torque Servo 400,00
1-HRC35745S Hitec HS-5745MG Digital Giant Scale Servo 180,00 baja hpi
Lombada, estou tentando te ligar...quanto as peças de reposição, fico com todas.
NO RACE - YES PACKS²
Menos as bandejas...Drake´s escreveu:Lombada, estou tentando te ligar...quanto as peças de reposição, fico com todas.
O power supply bulldog já tem dono......mandei MP bem cedinho rsrsrs
1-ASC89028 Team Associated Steering Blocks (RC8/RC8T) 60,00
1- jogo rolamentos ASC89160 Team Associated Drive train Bearing Set (RC8) 200,00
e ia lombada td joia, tem um amigo meu que tem interesse em 1-6v 1500mh ni-mh receiver pack dynamite - 30,00 usado
esse pack é aquele montado com 5 baterias em linha ou 3 em baixo e 2 em cima ?
quanto tempo de uso as baterias ?
3 em baixo e 2 em cima pouco tempo usei umas umas 5 vezes
lombada, vou ficar com 1-6v 1500mh ni-mh receiver pack dynamite -
passa dados para deposito no meu email
gustavo.abrinhosa@andritz.com
sedex para 13274-340
- gugacertain
- Registrado em: 19 Set 2007, 22:00
Lombada, fico com os Crime Fighters
Eu faço samba e amor ate mais tarde e tenho muito sono de manha....
