Losfer escreveu:Comparação de servos
Código: Selecionar todos
Fabr/Modelo Torque Velocidade Futaba S135 - 0.15sec/60Deg Futaba S3001 42oz/in 0.22sec/60Deg Futaba S3003 44.4oz/in 0.23sec/60Deg Futaba S3010 6.5kg/cm 0.16sec/60Deg Futaba S3305 8.9kg/cm 0.2sec/60Deg Futaba S5050 19.0kg/cm 0.2sec/60Deg Futaba S9250 5.5kg/cm 0.11sec/60Deg Futaba S9350 10.0kg/cm 0.12sec/60Deg Futaba S9402 110oz/in 0.10sec/60Deg Futaba S9404 79.2oz/in 0.11sec/60Deg Futaba S9450 8.0kg/cm 0.1sec/60Deg Futaba S9451 8.7kg/cm 0.1sec/60Deg Futaba S9650 4.5kg/cm 0.11sec/60Deg Hitec HS-322HD 3.7kg/cm 0.19sec/60Deg Hitec HS-325HB 3.7kg/cm 0.15sec/60Deg Hitec HS-475HB 5.5kg/cm 0.18sec/60Deg Hitec HS-525MG 4.1kg/cm 0.13sec/60Deg Hitec HS-5475HB 4.4kg/cm 0.23sec/60Deg Hitec HS-5625MG 7.9kg/cm 0.17sec/60Deg Hitec HS-5645MG 10.3kg/cm 0.23sec/60Deg Hitec HS-5925MG 7.4kg/cm 0.1sec/60Deg Hitec HS-5945MG 11kg/cm 0.16sec/60Deg Hitec HS-60 1.1kg/cm 0.17sec/60Deg Hitec HS-645MG 9.6kg/cm 0.2sec/60Deg Hitec HS-81MG 3kg/cm 0.09sec/60Deg Hitec HS-945MG 8.8kg/cm 0.16sec/60Deg KO PROPO PDS-2144FET 13kg/cm 0.13sec/60Deg KO PROPO PDS-2343FET 8kg/cm 0.08sec/60Deg KO PROPO PDS-2344FET 13kg/cm 0.13sec/60Deg KO PROPO PS-2113FET 9.5kg/cm 0.06sec/60Deg KO PROPO PS-2173FET 8kg/cm 0.09sec/60Deg KO PROPO PS-2174FET 12kg/cm 0.13sec/60Deg SANWA ERG-WRX 8.1kg/cm 0.06sec/60Deg SANWA ERG-VRX 8.0kg/cm 0.07sec/60Deg SANWA ERG-VX 13kg/cm 0.01sec/60Deg fonte: http://www.rcbaby.com/npnuke/modules.php?op=modload&name=Reviews&file=index&req=showcontent&id=25[/quote] A velocidade é essa mesmo ou foi erro de digitação? [color=red]SANWA ERG-VX 13kg/cm 0.01sec/60Deg[/color] , se realmente for isso realmente é um servo muito rápido...
Comparativo de servos - c/ planilha
Re: Comparativo de servos - c/ planilha
http://www.servodatabase.com/servo/airtronics/94359z
Torque: 4.8V: 160.0 oz-in (11.52 kg-cm)
6.0V: 200.0 oz-in (14.40 kg-cm)
Speed: 4.8V: 0.13 sec/60°
6.0V: 0.10 sec/60°
ou
http://www.servodatabase.com/servo/airtronics/94361z
Speed: 4.8V: 0.09 sec/60°
6.0V: 0.07 sec/60°
tem q ver qual dos dois é, porem ta com erro de digitação sim..
6.0V: 0.10 sec/60°
ou
6.0V: 0.07 sec/60°
Pessoal
eu n sou muito entendido de Servos...
Quero trocar os da minha Revo.
O que vcs indicam?
14kg e 0.07s
ou
20kg e 0.15s
O que vcs indicam?
14kg e 0.07s
ou
20kg e 0.15s
Crawlers/Escala Brasília http://www.rcmasters.com.br//viewtopic. ... 82#p406182
VENDO SAVAGE 4.6 http://rcmasters.com.br//viewtopic.php?p=439289#p439289
E ai galera, estava olhando algus sites e me deparei com este servo: 14 Kg, 0,17seg. e o melhor por 98,00 reais na Milinfo.
Gostaria de saber se alguem ja usou esta marca, me disseram que não serve em qualquer rádio ou bateria ( ão achei nada sobre issso).
Gostaria de por este servo na REVO
Caso alguem conheça por favor me dê mais informações.
segue o link do fabricante:
http://www.blue-bird-model.com/index.html - Fabricante
http://www.blue-bird-model.com/en/servo ... 0mghs.html - servo
Valeu.
Valeu.
Fala.
Bom sou novo aqui, sou de São carlos e gostaria se alguem pudesse ajudar, Acabei de importar um O donnel Z01B e gostaria de alguem soube quais servos são efetivos nele, sendo um pouco mais em conta devido o BLS352/ BLS351...são muito caros...
Qualquer servo tamanho standard funciona..
Se for mesmo competir, estes servos são um bom começo..
Se for brincar, um Futaba 3305 já dá pro gasto..
OU procure por um Spektrum DS821..
Boa!abib escreveu:Qualquer servo tamanho standard funciona..
Então Abib, qualquer servo com tamanho de 1.6 x 0.8 x 1.5 ´´ é aplicavel?
muito obrigado
- Herr_Roehrig
- Registrado em: 11 Jul 2010, 22:00
Não sei se você já trocou seus servos, mais eu estava com problemas nos originais da Traxxas do meu E-Revo Mamba Monster... eu ando com 6S e os servos tão oscilando e causando uma baita instabilidade. Estive procurando em outros foruns e me falaram bem da marca Savox, acabei comprando hoje dois do modelo SC-1268MG para 26Kgs. O preço é meio salgadinho mas pra segurar o bicho tem que ser algo bem forte e que aguente as lipos também. Falaram que teria que ser high voltage e ultra torque. Andei comparando com outros da Hitech e Futaba e esses sairam mais em conta. Depois que eu instalar e testar os servos coloco aqui as impressões.Danielk escreveu:Pessoal
O que vcs indicam?
14kg e 0.07s
ou
20kg e 0.15s
Abraço,
Rodrigo
Herr_Roehrig escreveu:
Abraço,
Rodrigo
Ainda não comprei não...
gastei um pouco nos meus eletricos.
Savox eu acho uma boa opção.
Mas vc comprou dois de 26!? será que um só não resolvia? Afinal com dois traxxas vc tinha +-16Kg , 10 Kg a menos que um Savox sozinho.
- Herr_Roehrig
Então Danielk, comprei dois servos porque tenho um Summit também, ainda não deu problema com ele, mas caso fique exagerado os dois no E-Revo eu coloco um em cada carro.
Abraço,
Rodrigo
Abraço,
Rodrigo
Ahhh
é melhor mesmo usar dois servos pra distribuir melhor as pancadas
- Herr_Roehrig
No meu caso Danielk eu pensei em usar dois fortes assim pra segurar o carro em linha reta, pois só ando com 6S e mandando ver mesmo! Já tô preparando a suspensão mais baixa, o silicone dos amortecedores mais denso, as molas mais rígidas pra ver o carro mais estável em alta velocidade. Depois de testar os servos novos eu coloco o carro no circuito oval e filmo. hehehehehe
Abraço,
Rodrigo
Abraço,
Rodrigo
Mas o arquivo ta off já ...eheehhhe...
