Peças p/ Team Losi 8ight, velas novarossi e mais!
- kaduozores
- Registrado em: 13 Nov 2007, 21:00
Codigo QNTDADE R$ unitario
AMBrc DP TRANSPONDER 1 270,00
LOSA 1700 front suspension arm set 2 35,50
LOSA 1722 rear suspension arms 1 35,50
LOSA 4002 antena kit 1 7,50
LOSA 9107 clutch shoes (2) composite 2 31,00
LOSA 5430 15mm shock bladders 1 12,00
LOSA 9348 rear exhaust mainfold gaskets 2 8,50
LOSB 5009 fuel filter heat resistant (2) 2 12,00
LOSA 6047 5mm rod end set 1 9,50
LOSA 5429 shock o-ring set 1 9,50
LOSA 9316 fuel line clips (4) 2 7,00
LOSA 5413 15mm shock shaft 4x57mm TiN(1) 1 24,00
LOSA 5411 15mm shock shaft 4x50mm TiN(1) 1 24,00
LOSA 3505 diff seal set 1 12,00
LOSA 9104 clutch pins & hardware, 4 shoes 2 14,50
LOSA 9109 long-wear aluminium clutch shoes (4) 1 70,00
LOSA 3518 drive pin set 1 9,50
LOSA 5434 15mm shock ends, cups, bushing 1 21,50
LOSA 8099 8ight buggy body, masks, stikers 1 64,50
LOSA 1730 rear hub carriers 1 21,50
LOSA 4409 steering bellcrank plastcs 1 16,50
LOSA 1707 front spindles 2 29,00
LOSA 1710 front spindles carriers 1 35,50
LOSA 4427 front gearbox 1 21,50
DYN 2510 Dynamite Nitro Glow Plug Wrench 1 21,00
DYN 8713 .21 engine header seal, purple 1 26,00
XRA 940610 XRAY 6x10x3mm Rubber Sealed Ball Bearings (2) 2 11,50
NVR 60001 Novarossi Long Spring for .21 Engine Manifold (3.7mm x 90mm) (3) 1 20,50
Vela Novarrosi Turbo C7TF 4 30,00
Vela Novarrosi Turbo C6TF 7 30,00
ADBV513R 5X13 rubber sealed ball bearing (10) 1 26,00
kyosho dish whell (4) 1 55,00
- kaduozores
Re: Peças p/ Team Losi 8ight, velas novarossi e mais!
Todas as peças sao novas, sem uso, na embalagem original.
LOSA 9104 neste item vem aqueles parafusos q seguram as sapatas???
se sim eu quero
se sim eu quero
a é do 2.0??felipeps escreveu:LOSA 9104 neste item vem aqueles parafusos q seguram as sapatas???
se sim eu quero
- Fastinhu
- Registrado em: 11 Jun 2010, 22:00
fico com LOSA 9348 rear exhaust mainfold gaskets 2 8,50
Eletrico é brinquedo??
Poe do lado então!!hahaha
- kaduozores
Sim, são os parafusos que seguram as sapatas do 8ight 1.0felipeps escreveu:a é do 2.0??felipeps escreveu:LOSA 9104 neste item vem aqueles parafusos q seguram as sapatas???
se sim eu quero
as do losi 2.0 é losa9106(essa eu nao tenho).
Olhando pela foto e comparando com a minha aqui nao da p/ perceber diferença.
Ai você decide.
- kaduozores
Lista atualizada tudo novo, na emblagem original.
Codigo [ QNTDADE ] R$ Unitario
GT01K-21BU GRP PROMOKIT .21 [ 1 ] R$ 925,00
AMBrc DP TRANSPONDER [ 1 ] R$ 270,00
LOSA 1700 front suspension arm set [ 2 ] R$ 35,50
LOSA 1722 rear suspension arms [ 1 ] R$ 35,50
LOSA 4002 antena kit [ 1 ] R$ 7,50
LOSA 9107 clutch shoes (2) composite [ 2 ] R$ 31,00
LOSA 5430 15mm shock bladders [ 1 ] R$ 12,00
LOSB 5009 fuel filter heat resistant (2) [ 2 ] R$ 12,00
LOSA 6047 5mm rod end set [ 1 ] R$ 9,50
LOSA 5429 shock o-ring set [ 1 ] R$ 9,50
LOSA 9316 fuel line clips (4) [ 2 ] R$ 7,00
LOSA 5413 15mm shock shaft 4x57mm TiN(1) [ 1 ] R$ 24,00
LOSA 5411 15mm shock shaft 4x50mm TiN(1) [ 1 ] R$ 24,00
LOSA 3505 diff seal set [ 1 ] R$ 12,00
LOSA 9104 clutch pins & hardware, 4 shoes [ 2 ] R$ 14,50
LOSA 9109 long-wear aluminium clutch shoes (4) [ 1 ] R$ 70,00
LOSA 3518 drive pin set [ 1 ] R$ 9,50
LOSA 5434 15mm shock ends, cups, bushing [ 1 ] R$ 21,50
LOSA 8099 8ight buggy body, masks, stikers [ 1 ] R$ 64,50
LOSA 1730 rear hub carriers [ 1 ] R$ 21,50
LOSA 4409 steering bellcrank plastcs [ 1 ] R$ 16,50
LOSA 1707 front spindles [ 2 ] R$ 29,00
LOSA 1710 front spindles carriers [ 1 ] R$ 35,50
LOSA 4427 front gearbox [ 1 ] R$ 21,50
DYN 2510 Dynamite Nitro Glow Plug Wrench [ 1 ] R$ 21,00
DYN 8713 .21 engine header seal, purple [ 1 ] R$ 26,00
XRA 940610 XRAY 6x10x3mm Rubber Sealed Ball Bearings (2) [ 2 ] R$ 11,50
NVR 60001 Novarossi Long Spring for .21 Engine Manifold (3.7mm x 90mm) (3) [ 1 ] R$ 20,50
Vela Novarrosi Turbo C7TF [ 4 ] R$ 30,00
Vela Novarrosi Turbo C6TF [ 7 ] R$ 30,00
ADBV513R 5X13 rubber sealed ball bearing (10) [ 1 ] R$ 26,00
kyosho dish whell (4) [ 1 ] R$ 55,00
nao tem pinhao de 13t?
- Fastinhu
User recomendadissimo,muito rapido no envio das peças q comprei
- kaduozores
- juninho_foz
- Registrado em: 03 Set 2010, 22:00
ESSAS VELAS ..da certo no SC8..motor .28
- cardoso789
amigo aquela peça xray que peça é ?
- thomas.vx3
- Registrado em: 04 Set 2008, 22:00
Kadu, mandei mp com lista de peças que vou ficar.
Thomas
Thomas
-Fast and Cheap... Not Reliable
-Cheap and Reliable... Not Fast
-Fast and Reliable... Not Cheap
- kaduozores
Respondidos via mp
- kaduozores
Lista Atualizada
