GRP Gandini PNEUS MONTADOS 1/8 Atomic Tire Medium White Dish Wheel
MAIS INFORMAÇÕES
This is the Gandini Racing Production 1/8 scale Off-Road
Atomic Tire Mounted on White Dish Wheels.
FEATURES: Atomic Micro Pin Style Tire-Medium Compound
White Dish Wheel with Relief Cutouts
Molded Foam Inserts
Pre-Mounted and Glued
17mm Hex Style Mounting
For Front or Rear Use
Made in Italy
INCLUDES: Two Off-Road Tires mounted on White Dish Wheels
REQUIRES: Installation on wheel hub
SPECS: Tire-
Outer Diameter: 4" (103mm)
Inner Diameter: 3.1" (79mm)
Width: 1.63" (41mm)
Wheel-
Outer Diameter: 3.1" (80mm)
Width: 1.63" (41mm)
Mounting Style: 17mm Hex Style
Rodas montada , com muito pouco uso ..
Fotos Por Email .
Obrigado
Rodas com Pneu GRP 1/8 17mm
- murillosalla
- Registrado em: 21 Nov 2009, 21:00
Xray T2-07
- nbrancalhaojr
